RCU Forums
-   Tips & Techniques (https://www.rcuniverse.com/forum/tips-techniques-180/)
-   -   ...cut flex cable? (https://www.rcuniverse.com/forum/tips-techniques-180/1798738-cut-flex-cable.html)
stevehord 05-08-2004 11:54 PM
...cut flex cable?
Does someone have tips / advice for the best way to cut flexible throttle cable for a 1/2a Herr cub w/Norvel .061? I have read several RC magazine recommendations about the BB Tools classic cutter. Does anyone have these cutters ...do you like them? I just haven't had much success cutting these flexible cables without unraveling or fraying them; probably because of the standard wire cutters I use.
Steve Hord
blvdbuzzard 05-08-2004 11:58 PM
RE: ...cut flex cable?
I solider the area I am cutting and use sharp cutters. I have also used shrink tube to hold the strands in place.
Dru.
FHHuber 05-09-2004 12:44 AM
Definitely solder-fill then cut. Saves all kinds of hassles with frayed ends.
TLH101 05-09-2004 07:33 AM
You can cut it with a sharp chisel on a vise anvil without fraying, but I prefer to solder the area to be cut like the others recommended.
Ed Smith 05-09-2004 07:51 AM
I solder first then cut on the bench grinder or a dremel cut-off disc.
Ed S
DBCherry 05-09-2004 09:18 AM
Soldering first definitely prevents fraying, but in some cases can also prevent the cable from easily fitting through a small opening. In those cases I find a Dremel cut off wheel, used carefully, will work.
Dennis-
LesUyeda 05-09-2004 09:21 AM
Micro Mark, Item #82477. Indispensible!!
http://www.micromark.com/
Les
SST 05-09-2004 09:25 AM
Wrap the cut point with masking tape in the opposite direction of the cable's twist looking from the end you will be using), and use a cut-off wheel. Set it up so you cut through at the center of the tape.
rajul 05-09-2004 09:34 AM
Solder, cut to desired length, taper file end
BasinBum 05-09-2004 12:30 PM
TLH101,
I really hope you are not using a wood chisel to cut cable on a vise, it'll send metal chips flying at a really high rate of speed.
Wrap it in tape and use a sharp pair of diagonal cutters.
Kmot 05-09-2004 01:42 PM
LOL, everyone has their own version. Me too! I just use very sharp high quality dykes. Doesn't unravel, and then I solder the end. I chuck it up in my cordless drill and use sandpaper to smooth it down.
J_R 05-09-2004 01:55 PM
Compound cutters. The cut music wire to 3/16 like butter.
http://buy1.snapon.com/catalog/Pro.a...e=snapon-store
Second choice is a Dremmel with a cut-off wheel.
TLH101 05-09-2004 03:12 PM
B/B
Why do you persit in presumeing everybody is too stupid to be a modeler. Why would anyone try to cut metal with a wood chisel?:eek:
DustOffUH1 05-09-2004 03:56 PM
A guy whose been building for years, taught me, as stated above, to solder the end then cut and file smooth. Works great! BTW I'm going to start building the same Herr 1/2 A J3 Cub. I bought the same engine too. Looks like a nice kit. How's your build going? It looks like a fairly straight forward build, but, any advice/tips on the kit would be appreciated.
Joe
One more question, did you get the Grish Tornado prop, if so where did you find it?
Thanks!
Ed Smith 05-09-2004 04:09 PM
Well, all of my screwdrivers are too blunt!
Ed S
BasinBum 05-09-2004 10:07 PM
ORIGINAL: TLH101
B/B
Maybe because they are too stupid to spell "persist" or "presume".
DustOffUH1 05-09-2004 10:43 PM
Cheap shot :eek: The spell checker is a PITA to use, which has been "temporarily" not fully functional. Gee,,, I hope I spelled everything correctly :D Don't want to get scolded [&:] Stay on the subject :eek: and don't worry about how people spell, please... its a BB, punctuation and speeeeelllllinkk are "optional".
Joe
TLH101 05-10-2004 07:23 AM
Sorry, I am not as "PERFECT" as B/B, I am just a normal person who does spell wrong at times. I guess I should try to rise to his pedestal.
DrFun 05-12-2004 12:54 AM
Well I couldn't find the flux last time I was going to cut the cable and the solder did not stick.
So I heated the loaction where I wnat to cut from with a small butane torch to red hot for 30 seconds and then cut it with dremel. It was easy and intact. plus putting through the plastic housing was easy as there was no thickness of solder.
Heating to red hot might have strength issues but you really don't need strength at tha 1/4" section of the cable.
edit: spell
jessiej 05-12-2004 02:34 AM
Strange how times change. Back in those long ago days before spell checkers we had a thing called a "dictionary" with which one could determine the proper spelling of a word, and even if it was the appropriate word, unlike these modern things. At that time, of course correct spelling was considered not only important to concise communication, but an indication of the education of the writer and his attention to detail. The matter was given such emphasis that people were actually taught to spell with no outside assistance at all! Imagine that.
Another quaint attitude prevalent at the time was that exchange of insults indicated a lack of maturity and if done anonymously was cowardly.
People sure had some strange ideas back then.
jess
SST 05-12-2004 10:12 AM
ORIGINAL: jessiej
jess
And the correct use of punctuation. A mislocated period or comma, or lack of same, can alter the meaning of an entire sentence. Sometimes the whole paragraph. Then the poster gets all upset :( when the responses aren't what was expected, or are not forthcoming at all because noone can decypher what was said. Of course a fourth-grade spelling level doesn't mean they can't graduate from college:eek:...If they can play Varsity sports.;)
tommy s 05-12-2004 11:14 AM
Why don't you guys lighten up ? This is supposed to be a fun , relaxing hobby.
This fellow was just asking a simple question about a cable.
tommy s
DustOffUH1 05-12-2004 11:20 AM
I Tootallly Aggreea :D
sooorrryy stilll at kintergarten levell
BasinBum 05-12-2004 12:33 PM
I was going to drop it and let THL have the last word but since it keeps getting off track....
I suppose I instigated this with my reply regarding what type of chisel to use because some out there just might read the post and use a wood chisel. THL took my comment way to personal and flamed me for it. I would recommend to him and everyone else to not take things so personal especially when they do not clearly defame your character. I did blast him in return for what was clearly a slander of my character as I never pass up an opportunity to do so, if you've been on RCU for a while you know what I'm talking about. So THL can have the last word now as I'm done with this thread as long as nobody casts aspersions my way.
DustOffUH1 05-12-2004 12:43 PM
At least you spelled everything correctly :D OK I'm done being a smart *ss He got the answer to his question, and that's the most important thing. IMO [&:]
