Incidence meter?
Hello
I am looking for an incidence meter to measure stab, wing incidence and engine thrust. Do you have any ideas wich company sell one? Daniel |
RE: Incidence meter?
Robart sells them ( www.robart.com) and Great Planes makes a laser one.
1 Attachment(s)
You can also make one for about $5.
Edwin |
I have the Great Planes Laser one. I have found it to be easy to use and very accurate. If you get the GP one, you may want to put a LITTLE locktite on the adjustment wheel so it is harder to turn. I have found the wheel is very easy to knock out of adjustment as it comes from the box.
What i have seen is Robart sell an anlalog meter at 38$ and Great planes sells a laser meter at 20$ that should be more accurate than Robart one?
Can Great planes meter measure negative angle or only positive incidence?? |
I cut and pasted this from the Tower web site. These are the specifications for both.
I have both and I like the Great planes product better in general. The Robart clamping arms are nicer than the Great planes product. It seems from other posts on incidence meters, it is about an even split for preference. They are both good instruments. Greg GREAT PLANES NOTES FROM OUR TECH DEPARTMENT This is the AccuPoint Laser Incidence Meter from Great Planes. This High Precision Tool is used to find Accurate Angle Alignments on Airplane Wings, Stabilizers or Engine Mounts. FEATURES: Integrated use of laser beam pointer is much more precise and trustworthy than the weighted pointers and bubble levels found in other meters giving modelers pinpoint accuracy. (See COMMENTS) The laser unit rests in a ball bearing supported yoke that eliminates binding and adds to the meter's precision. The big scale is easy to read from any angle, and measures incidence down to 1/4 of a degree. Reads 0-10 positive and negative. The grippers on the clamps are perfectly aligned to stay true over time, and the opposed, large-radius thumb screws are easy to access and use. It is designed to be set on a flat surface to "zero it out" with a knurled adjustment thumb wheel before use. Special notch at the bottom of the scale allows it to be attached to an engine crankshaft for checking the engine's thrust angle. Fits wing chords upto 16" Accommodates wider wings with an optional 36" long aluminum bar INCLUDES: One Laser Pointer with Yoke Assembly (See COMMENTS) One Magenta Red Aluminum Bar One Incidence Meter Scale/Engine Thrust Mount Two Clamping Jigs with Thumb Screws REQUIRES: Assembling of the Laser Incidence Meter SPECS: Bar Length Overall: 20" Length Between Clamping Jigs: 16-1/4" Scale Height: 8" COMMENTS: Warning: This unit comes with a device that emits a laser light. This can be harmful to eyes if looking directly into the light. This along with other laser type equipment should be handled carefully. NEVER LOOK INTO THE LIGHT BEAM, and never point the laser towards anyone. The AccuPoint can be used to check: The wing at the root and tip, for warping. That the stabilizer is aligned with the wing (thrust line). That the wing and stabilizer are both level. The engine's thrust line. That the fuselage is level. Helicopter blade pitch. ROBART This is an Incidence Meter is for Setting Proper Thrust, Wing and Stabilizer Incidence on Model Airplanes or is Used to Determine Why a Model is Not Flying Straight. This Will Work On All Model Airplanes with Wing Chords of 15.25" or Less. Robart offers an extension for large wings, but we don't carry it(see COMMENTS) FEATURES: Magnified Window, Anti-Parallax, Jeweled Movement Scale Meter. Reads Within 1/8th of One Degree. Bearing Mounted Pointer With Mirrored Surface Behind For Easy Viewing Steel Counterweight Bubble Level A Must For Building True and Straight Airframes No-Slop "V-Block" Clamps INCLUDES: One Model Incidence Meter Two "V-Block" Clamps One 18-1/16" Long Parallel Bar One Instruction Booklet REQUIRES: Assembly of Incidence Meter. COMMENTS: Robart does make a 36" Parallel Bar part #404029M (we do not carry it, but they will sell directly to the public). |
| All times are GMT -8. The time now is 11:45 AM. |
