Pull-Pull Bellcrank
How do you guys make a Pull-Pull Bellcrank(for the rudder in my case), do you connect the servo arm to a small rod and to a long servo arm with bolt and a lock nut, or buy it from someone?
RE: Pull-Pull Bellcrank
Nelson products makes several with ball bearing smoothness-that is what I have been using
I made the one on my Ultimate from a Dubro heavy duty servo horn and two mixing arm bearings from a model helicopter. I have used the Nelson offerings, and they were excellent. I just had to wait three weeks to get the one I wanted.
If you're doing a big model, I would spend the bucks and get a Nelson. If you're dealing with a 120 or so size model, making one out of available material is fun and educational. If you're interested, I can post a photo of my homemade one when I get home this evening. |
Please do so
| All times are GMT -8. The time now is 02:51 PM. |
