RCU Forums
-   Tips & Techniques (https://www.rcuniverse.com/forum/tips-techniques-180/)
-   -   i need help to cover my plane! (https://www.rcuniverse.com/forum/tips-techniques-180/2557020-i-need-help-cover-my-plane.html)
Murdoc 01-18-2005 09:53 PM
Help!!
i"m trying to cover my trainer, but the result is only bad wrinkly covering.....
any tip how to avoid wrinkly covering?
campbec 01-18-2005 11:05 PM
RE: i need help to cover my plane!
Hi,
For the purpose of this reply I will assume that you are covering using a plastic shrinkable film with heat activated adhesive.
You will need at minimum a covering iron, a number of sharp hobby knife blades or similar, a straight edge, a good sharp pair of scissors and masking tape.
Check you have sanded the surfaces to cover as smooth as possible. Then sand again. Use a vacuum cleaner or air gun to remove the dust and then follow up with a tac-rag.
Cut the pieces of covering about 50mm larger than the surface to be covered. Set your iron to the covering manufacturers recommended heat or experiment with scraps until you get the temperature correct.
Tack the covering, (having removed the backing) adhesive side down at the centre of one end just pulling tight enough to remove wrinkles and work end to end corner to corner, (a bit like the sequence of tightening the nuts on a vehicle's wheel). Then seal the edges down. On the fuselage do the bottom and rear first working from bottom to top and rear to front. On the wing do the bottom surface first followed by the top. Once you have sealed the film down turn the heat on the iron up and shrink the plastic tight, (a heat gun makes this part easier). Care is needed not to burn a hole in the covering.
There are many threads on covering including some illustrating the covering sequence. Some covering products show the sequence on their labels/info sheet.
There are also many other ways to cover and finish a model. LOL!
Cheers,
Colin
Murdoc 01-18-2005 11:22 PM
Thanks for a good reply!
the-plumber 01-19-2005 05:56 PM
ORIGINAL: colibri4
Help!!
Crash Campbell covered a lot, but all the other answers are [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXL792&P=ML]here.[/link]
crook 01-19-2005 09:59 PM
did you write that book?....................kinda weird why you would post that link, unless you were the writer of it. just my thoughts
Raghfrost 01-20-2005 04:39 AM
there is an article in RC http://www.rcuniverse.com/magazine/a...?article_id=67 check it out.. it helped me load heh. cheeers dude hope this helps
bps 01-20-2005 07:12 AM
I have a theory about film cover and the knowledge/skill it takes to apply. This stuff was invented so that the young guys that come into the hobby would have something to pull their hair out about therfore helping the young fellow to look more like the old fellas. I just have no idea how this affects the ladies? Kinda shoots holes in my theory.
Clueless JEB:D:eek:
the-plumber 01-20-2005 06:07 PM
ORIGINAL: crook
What's 'kinda weird' about providing a link to what is arguably 'the bible' for finishing model aircraft ?
BTW - my name is in my sig line below, and it's not "Harry Higley".
