Pull pull or normal push rod
I have an option on my Chipmunk to use either the pull pull or normal hard wire push rod on the rudder... so which one is better? For pull pull I have to move the servo a little back with some more work but push rod systems is straight forward.
So which one should I prefer...? |
If the pull-pull system is within your grasp, definately use it.
1. It weighs less. 2. Much more effective use of the rudder. 3. It will not flex or bend as with a pushrod. If using a pushrod, I would highly recommend carbon fiber as opposed to nyrod, metal, dowels, etc... JMHO |
Hi!
Thin fishing wire is best, and lighter than a pushrod. And does not transfer vibration back to the servo eighter! Carbon fiber rod or aluminum arrowshaft is what I use if I have to use a rod. In small planes, around 150cm span, I use 10x10mm balsa rods for elevator and rudder were I canīt use wires. Regards! Jan K Sweden |
Thin Fishing wire may not transmit vibration but it can be a source of glitching. I Use only Kevlar string and exit the fuse using teflon Tube. does not stretch with heat or cold like wire can...
Don/// |
I second the use of Kevlar. Holds up very well and soesn't stretch. I also think it is easier to work with than wire.
I have used pull pull wire cable a long time . It has worked for me on everything from park flyers to 1/4 scale. There are a lot of ways to rig with wire and it has never failed me yet
Kevlar
One of Kevlar's best attributes is that it doesn't stretch. I first encountered it when it was used in the early 80s as suspension lines on parachutes. However, it doesn't have much abrasion resistance, so mount your system in such a way as to prevent the Kevlar from rubbing on exit tubes, etc..
Otherwise, it'll "fuzz" up. |
Mike,
You are right about that! If you use kevlar you should inspect it occasionally as it is subject to fraying. I have both wire and kevlar pull/pull systems. My wire system is about 12 years old and still in good shape. My kevlar system has been restrung once, after about 3 years of use, due to fraying at the fuselage exit. Good systems, both of them, but they all need periodic inspections. Have fun! Bedford |
The abrasion factor s the reason I use the Teflon Tubing to exit or where the lines cross. Had a Pull pull on a 1/4 scale plane for years with no known problems
Don// |
| All times are GMT -8. The time now is 04:22 AM. |
