Will this work?
1 Attachment(s)
redxfred... I have that figured out already. :D :D :D Take a look the Rotary Driver System (RDS): http://www.proptwisters.org/rds2/
The wing is already built with RDS on each aileron and the inboard flaps (inboard flaps drives the middle and outboard flaps). Flaps up... |
Will this work?
1 Attachment(s)
Flaps down... (cool, huh?)
Will this work?
During the early 70"s when we used lenear servos, where the output shaft ran back and forth, we used a small brass tube bent in a half circle and ran plastic coated cable to the elevator. It is the same idea as the pully, but nothing to break. Just a thought..
Larry |
| All times are GMT -8. The time now is 11:57 PM. |
