Instrument panels made easy
Here is a link you can use to "build" your instrument panel, then print it out. You will need to use Explorer for this site.
http://www.epanelbuilder.com/index.htm |
RE: Instrument panels made easy
thats cool. good find
Seems to be ok. I tried printing out some pre made instruments and they printed ok.
Then tried making one and it printed, 8 1/2 x 11 portrait, however the instruments printed off to the right of the panel. Is this normal? |
Same for me... [:o]
I found out about this on another thread. You need to keep resizing the window, then do a print preview. By resizing the window, the instruments eventually will fit in the template. Not sure why this is, but this is how you fix the problem.
| All times are GMT -8. The time now is 02:10 PM. |
