RCU Forums
-   Tips & Techniques (https://www.rcuniverse.com/forum/tips-techniques-180/)
-   -   PIN POINT HINGES (https://www.rcuniverse.com/forum/tips-techniques-180/2791892-pin-point-hinges.html)
RAPPTOR 03-22-2005 06:39 AM
PIN POINT HINGES
BEST WAY TO GLUE ROBART PIN POINT HINGES?? C/A,EPOXY?? RD[:o]
exeter_acres 03-22-2005 07:39 AM
RE: PIN POINT HINGES
Here is a current open thread talking about this......
http://www.rcuniverse.com/forum/m_27...tm.htm#2787660
OverTheEdge 03-22-2005 12:40 PM
You will get several different answers to this... I just used them for the first time and went with 5min epoxy. Many will tell you poly glue, white glue, wood glue, canopy glue, 30min epoxy, 5min epoxy, etc etc etc... the poly glue sounds like a good idea since it expands but I didn't feel like babysitting it while it set-up to wipe off the foam that ooozzzes out. So I oiled the hinge, dabbed the 5min epoxy in both holes pressed it together waited 5min and I was done. They are solid. Only problem I see with this method is if you don't plan ahead or have some sort of problem while putting it all together you could be in deep doo doo... so if you think you'll need more time you might want to use 30min or one of the other glues.
the-plumber 03-23-2005 01:06 AM
I use [link=http://www.westmarine.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10001&langId=-1&catalogId=10001&productId=34042]these epoxy syringes[/link] to inject 30 minute epoxy into the holes before slipping the hinge points in place.
30 minute epoxy gives you more than sufficient time to align the hinges.
pettit 03-23-2005 07:08 AM
Pacer Hinge Glue works great. It expands the wood, which tightens it around the pin hinge, and when dry, it is tighter than you-know-who's hat band!
I've also used poly glue (Elmers brand) buit I agree it does take some experimentation and baby sitting to put the right amount into the hole and to keep it from foaming out all over the pivot point.
Kaos Rulz 03-23-2005 07:24 AM
Those syringes work great, but if you don't have one, try a soda staw. Pack as much epoxy into it as you can, then flatten the end and insert into the slot a squeeze out a small amount. You can do the same for drilled holes if using pin-point hinges; just match up the size of the straw to the drilled hole, or if the straw is over-sized, just firmly place over the hole and squeeze in what you need.
I like the larger diameter straws you get when you order a milkshake. It's easier to put the epoxy in the straw, but more importantly -- I like milkshakes! :D
saramos 03-23-2005 10:18 AM
ORIGINAL: ED STEFAN
I've used this method and have a word of CAUTION to all:
FINISH THE MILKSHAKE BEFORE USING THE STRAW FOR APPLYING EPOXY!
And for those of you who are wondering, no, it doesn't matter what flavor milkshake you use. I know it may be hard to beleave, but the flavor will not affect the cure rate or the strenght of the final bond.
Kaos Rulz 03-23-2005 12:43 PM
ORIGINAL: saramos
ORIGINAL: ED STEFAN
