RCU Forums
-   Tips & Techniques (https://www.rcuniverse.com/forum/tips-techniques-180/)
-   -   Electric Starter (https://www.rcuniverse.com/forum/tips-techniques-180/3568483-electric-starter.html)
Trucker12 11-19-2005 05:59 PM
Electric Starter
Has anyone heard of useing a cordless drill to start a gas engine. Sounds alot cheaper than buying a high torque starter. Have a G-38 with no spring and looking for a starter.
Skinny Bob 11-19-2005 06:14 PM
RE: Electric Starter
Not a bad idea, but I think the RPM would be to low.
mrbigg 11-19-2005 08:47 PM
There's guys using a 100 dollar craftmen drill. I seen a vid of a guy starting a Poulan 46 with it.
racher 11-19-2005 08:54 PM
It works, a member at the field I used to fly at uses those. I did the same thing, bought a rubber insert and metal piece for a starter, cost $10. I then used an existing dewault drill. Works great.
-Eric
skypupmut 11-20-2005 06:23 AM
I use a crafsman 18 volt that turns faster than1200 rpm
works good on us engine and 50 cc twin
RCVFR 11-20-2005 09:17 AM
ORIGINAL: Trucker12
The G38 is one of the better hand starting engines out there. Save your money and just hand crank it?
sebo 11-20-2005 08:42 PM
Mine hand cranks with a couple of flips. Great engine G38
krazycdn 03-25-2006 11:16 AM
yes i have used cordless drills and I have made my own adapters aswell they work fine
mrbigg 03-25-2006 03:40 PM
Just seen the Sears ad and they have a 19.2 volt drill for 99.99.
Test005 03-28-2006 10:52 AM
I've used a 12V Bosch drill to start a .50 helikopter engine.
Works great!
