RCU Forums
-   Tips & Techniques (https://www.rcuniverse.com/forum/tips-techniques-180/)
-   -   Adding Weight... How? (https://www.rcuniverse.com/forum/tips-techniques-180/365258-adding-weight-how.html)
bkresse 11-14-2002 03:30 PM
I’m currently balancing my Ultra Sport 40, Ultra Stick 40, and Avistar 40 and have a few questions.
The Avistar balance was pretty close so I haven’t made any adjustments to it to date. It would probably benefit from an adjustment. However, it files pretty well now.
The Ultra Stick 40 was balanced (front to back) by attaching stick on weight (3 oz.) to the bottom of the fuselage at the tail. It is exposed, basically just attached to the outside of the fuselage. I haven’t added the weight to balance the wings (side to side) but it needs some adjustment.
I haven’t begun to balance the Ultra Sport 40 (ARF) yet.
My questions:
What is the best way to actually attach this weight? When I added weight to the Ultra Stick, I just attached it to the outside of the fuselage (using a little glue and a couple screws). This is OK but it doesn’t look very good. And now that I have to add weight to the wing – I don’t know where to actually add it.
Do I cut the covering and add it to the inside of the wing?
Does anyone have any great ideas for adding weight?
Thanks in advance for your help!
Brian Kresse
Flyboy Dave 11-14-2002 04:27 PM
Ultra Stick .40
I cut out the first inboard panel on mine, and added
3/4 oz. , then recovered with white. I didn't wanna
mess with the tip.
cwat212 11-14-2002 07:50 PM
Insert a screw or nail in the end of the wingtip. Put a drop of glue to hold it in place. Works well and all that shows is the head of the screw or nail. You can even apply covering over it if wanted. :)
MinnFlyer 11-14-2002 08:44 PM
Cut a little pocket into the wingtip (assuming it's solid balsa) and epoxy in a few "split-shots" (fishing weights). Then, balsa filler, and re-cover.
Flyboy Dave 11-14-2002 09:06 PM
Nasty wing tip....
1 Attachment(s)
....not only is the wing tip not solid, it's "framed" on
inside, and hollow. Add to that, it's less than 10 mm
thick. That's why I had to bite the bullet, and cut the
underside panel out. :eek:
Trust me....i would have prefered to do it another way.
And it needs 3/4 to 1 oz. of weight. :(
Dave. :)
Flyboy Dave 11-14-2002 09:20 PM
1 Attachment(s)
A decent patch-job, and the "operation" is all but
invisable. :D
