RCU Forums
-   Tips & Techniques (https://www.rcuniverse.com/forum/tips-techniques-180/)
-   -   Broken Rib Repair Method (https://www.rcuniverse.com/forum/tips-techniques-180/4115155-broken-rib-repair-method.html)
Harleyflyer 04-02-2006 01:08 PM
I got a new OMP Kat 70 V2 ARF recently and I noticed that the top of one of the ribs is broken but it is still in place. What I was wondering is if I could take a syringe, put some CA in it and then stick it through the covering to fix it. Would this be a good option to try? I just want to try and avoid having to cut and peel the covering back to do the repair.
Thanks in advance.
Flyboy Dave 04-02-2006 02:14 PM
RE: Broken Rib Repair Method
It might be worth a try....or cut and repair it from the bottom. Then again, you
might just leave it alone for now. Haven't you ever ruined something....
....by trying to "make it just a little bit better"? :eek:
FBD. :D
Harleyflyer 04-02-2006 09:50 PM
Flyboy Dave,
You might have a very good point! :eek:
Regards,
Keith
