RCU Forums
-   Tips & Techniques (https://www.rcuniverse.com/forum/tips-techniques-180/)
-   -   Broken wing dowels, help (https://www.rcuniverse.com/forum/tips-techniques-180/4306883-broken-wing-dowels-help.html)
bipeflyr 05-22-2006 09:03 PM
I crashed my Excelleron 90 into trees this weekend and suprizingly enough it suvived very well exept the 2 dowels in the front middle of the wing that locate the wing to the fuse. They both broke off at 3/8 to a 1/2 inch into the wing. It looks as if I could epoxy them into exact location but will this be enough to hold the wing?
I have also thought of doing this epoxy thing then drill down the middle of the dowel about 1 1/2 inches and insert 3/32 piano wire for strength.
Any ideas?
Flyboy Dave 05-22-2006 10:03 PM
RE: Broken wing dowels, help
Drill them out completely, and replace the whole length, it's easy to do. ;)
FBD. :D
bipeflyr 05-23-2006 12:17 AM
Thanks Dave,
The dowels were broke off splintered and at first I would think that the drill would walk around and get off center but I tried a forstner bit and it worked fine. I was hoping there would be an easier way than opening up the wing.
Thanks again
Flyboy Dave 05-23-2006 12:45 AM
Good show !! It took less time to drill 'em out than it did
thinkin' about it, huh ? ;)
FBD. :D
jaka 05-25-2006 10:54 AM
1 Attachment(s)
Hi!
I never use wood dowels ...Easton aluminum arrow shaft tubings are lighter and never wear down (compress) like wooden dowels.
Regards!
Jan K
Sweden
bipeflyr 05-25-2006 07:30 PM
Thanks Jaka,
I'll think about that next plane I build or repair dowels.
