RCU Forums
-   Tips & Techniques (https://www.rcuniverse.com/forum/tips-techniques-180/)
-   -   Canopy Glue clean up (https://www.rcuniverse.com/forum/tips-techniques-180/4684405-canopy-glue-clean-up.html)
azhar 08-29-2006 10:24 AM
What is the best way to clean out canopy glue?
Azhar
Safebet 08-29-2006 10:42 AM
RE: Canopy Glue clean up
Azhar, I don't know about cleanup,but I'm fixing to install my canopy on my Contender. Not much place to screw it on, so I was wondering if there is some kind of
silicone glue that I could use to run a bead on it and then set it in place.
With what and how did you attach yours?
azhar 08-29-2006 10:53 AM
Jim,
Canopy glue, the hobby store should knw what you are talking about, works great. It dries like silicone and is clear. I just goofed a little on my canopy alignment so need to clean off and reset it.
Azhar
Deadeye 08-29-2006 11:00 AM
A Q-tip and starting fluid (ether). Other solvents may work. Try a small spot to make sure your canopy isn't made of some cheap plastic that will fog with ether.
azhar 08-29-2006 11:12 AM
Thanks Deadeye. i will try that.
Azhar
Safebet 08-29-2006 11:40 AM
Thanks, Azhar. I will check at the LHS. Thank you, Deadeye for the tip in the event I smear some, too.
da Rock 08-29-2006 05:13 PM
Safebet,
Don't worry about smearing canopy glue. It's impossible to mess the job up. Have a damp paper towel ready. Make sure you run a bead of glue that is slightly too much glue. You want it to squeeze out. When it does, wipe it off with the damp towel. Tape the canopy in place and let the glue cure overnight.
It'll stay white looking for awhile, where it is thick. Don't worry about that either. It dries as clear as the canopy.
After you've got it taped, check after 10-15 minutes and wipe any more that might have squeezed out. The wet paper towel and the glue won't hurt anything. The glue wipes up great.
It's excellent stuff.
Safebet 08-30-2006 12:57 AM
darock, thanks for the helpful information. I will follow your instructions. Just hope my LHS has some.
Thanks, again
da Rock 08-30-2006 09:58 AM
Hey, I like the stuff go much, I'd ship you a bottle if the LHS doesn't have any. :D I think it's the next best new product since I found hinge glue. (have I told y'all about hinge glue???? :) )
On second thought, if the LHS doesn't have any, you need to find a better LHS..... grin
Razoo 08-30-2006 01:50 PM
Denatured Alcohol works great.
Safebet 08-31-2006 12:48 AM
Darock, can you give me a "brand name" of that stuff?
SMUGator 08-31-2006 12:53 AM
I can give you one - Pacer Formula 560 Canopy Glue. Looks and behaves just like white Elmers glue. Secures canopies like a rock.
Tom
*JCB* 08-31-2006 12:43 PM
The brand that I have used is called J&Z R/C 56 Glue. The stuff works very well, and dries clear and flexible, and cleans up quite easily.
I have a question of my own. Does anybody know if "Tacky Glue" is the same as canopy clue? It goes for about $0.80 vs $4.00 per 4oz container.
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXR529&P=ML]R/C 56 Glue[/link]
AA5BY 09-15-2006 01:27 PM
A sllightly different approach might be similar to how I recently intalled a wind screen on a Phaeton 90. First, a pattern was cut out leaving tabs to affix the screen rather than simply glue. Place pattern on model and mark tabs and then use pattern to cut wind screen. Use #11 blade to cut slots and then drag the blade backwards to open the slot slightly. Sand tabs to roughen and insert tabs into plane and either glue or pin from within. Straight pins can be used by heating and sliding along inside surface and sticking through the tab.
