RCU Forums
-   Tips & Techniques (https://www.rcuniverse.com/forum/tips-techniques-180/)
-   -   Using epoxy over a CA joint? (https://www.rcuniverse.com/forum/tips-techniques-180/4793578-using-epoxy-over-ca-joint.html)
N1EDM 09-25-2006 11:34 PM
I seem to remember something somewhere about not using epoxy over a CA joint, or was it the other way around?
I think that the reason is that epoxy won't cure if spread over a CA joint.
I'm working on a laminated stabilizer for my Bridi Brown B-2, using CA to adhere the laminations. Then I want to cover the stab with glass and epoxy for a Klasskote paint job.
Does anyone remember if this is true or not? Or do I even have it backwards? I just can't recall.
Bob
Flyboy Dave 09-26-2006 12:15 AM
RE: Using epoxy over a CA joint?
I use epoxy over CA all the time, no worries. ;)
TAZ 09-26-2006 11:44 AM
never had aproblem here..... i think it was an april fools or someone is pulling your leg
scratchonly 09-26-2006 02:44 PM
Epoxy is OK you may have trouble with polyester resin which won't cure over several contaminates.
majortom-RCU 09-26-2006 04:14 PM
You're more likely to get a poor joint if you try to CA something over an epoxy surface. Many epoxy formulations contain a wax component that migrates to the surface as the resin cures. I believe laminating epoxy may be the major exception. Just to be safe, before I try to glue anything over cured epoxy, I will sand the surface where I want to make a bond, to remove the wax.
Laying epoxy over a CA surface has never been a problem for me--just make sure the CA is cured first.
N1EDM 09-26-2006 06:21 PM
I remember reading this in some legitimate magazine/book somewhere. I just wish I could remember what it was.... it wasn't an old wives tale or someone yanking my leg.
I hadn't planned on using polyester resin anywa (too strong an odor) but I want to make sure that my laminations don't come apart by something in the epoxy adhesive attacking the CA.....
Bob
DMyer 10-04-2006 02:23 PM
I think you are confusing CA with polyester resin.... Polyester Resin will not cure over epoxy at the recommended levels of catylst. Few people use Polyester resin anymore as Epoxy Finishing Resins have all but replaced their purpose... without the fumes.
N1EDM 10-04-2006 05:57 PM
Thanks DMyer, but I was thinking specifically of CA, not the bit with Polyester resin.
I wish I could dig that up again. I just don't want to have laminations fall apart in flight if I'm wring.
Still and all, if not that many people are commenting on it, then it's not that big of an issue, I presume..
Thanks again for the comments though,
Bob
