RCU Forums
-   Tips & Techniques (https://www.rcuniverse.com/forum/tips-techniques-180/)
-   -   covering the holes (https://www.rcuniverse.com/forum/tips-techniques-180/5159207-covering-holes.html)
vasek 12-25-2006 10:52 AM
covering the holes
Hi guys,
I have trouble with the covering (ARF) over the stab "lightenig holes"
when the air heats up t tends to stretch the covering> when it cools down> wrikles (again)
pls help,
V.
tail strike 12-25-2006 11:09 AM
RE: covering the holes
dont heat it quite so much as to do that, and you can put a little pin hole in the covering on the bottom with a straight pin
I am watching you
larry S
ORIGINAL: vasek
Hi guys,
pls help,
V.
rcted 12-25-2006 04:44 PM
Hi,
Try poking a pin hole horizontally through the stab fron the training edge of the stab into the lightning holes. That will give the air a way out both during covering, as well as when the air heats up in the direct sun light.
rcted
vasek 12-26-2006 01:19 AM
Thanks guys, i new there was a way;)
daveopam 12-26-2006 10:42 AM
Dito on the pin holes.
