recovering
i want to recover my airplane but how do i remove the old "stick on" covering ?? i`ve taken the easy to remove stuff off. but what about the stubborn stuff? there`s also alot of the glue left on where the fuel was on the covering. i tried a iron but that didn`t work. is there a chemical that will remove the glue ? i tried alcohol with no luck. how about acetone or laquer thinner? thanks alot conk
recovering
I used acetone and heat gun....heat it up scrape it off then acetone to desolve glue.
Work small area at a time.... I did a 60 size Global trainer.....would I do it again NO Big Pain.... |
recovering
thanks for the tip. i knew there was a chem. to remove the glue.it`s to late to turn back now, i have most of it off the fuse. it was the ugliest plane on the field. it had so many patches of trimcote from accidents & hangar rash. i like building & covering. thanks again conk
| All times are GMT -8. The time now is 05:53 AM. |
