Cleaning for epoxy repair?
I'm geting ready to do some repairs to a boat that's had wax on it. It's car wax, so how hard is it to remove? There is some places where there is exposed wood so I don't want anything soking into it. The repairs will be done with epoxy, and the finish is epoxy too.
Thanks Shawn |
RE: Cleaning for epoxy repair?
Not really hard, but you do want to be thorough. There are products called "Deglossers" and solvent washes specifically to remove wax from fiberglass (The gelcoat/paint is often the first part of a boat that goes in a mold, on top of a layer of mold release wax. This wax has to be removed before adding trim or touch-up paints). Acetone will work, but you have to use lots of rags or you'll just spread the wax around and it will re-harden once the acetone evaporates off.
Option #2 Do the same procedure but use straight household ammonia followed by detergent wash and rinse.
Do either cleaning BEFORE ANY Sanding, you don't want the wax on the sandpaper. |
What you want to use is a product called "Prepsol" or a Poly Fiber product called "C-2210". You may be able to find Prepsol locally at a paint store or go online at http://www.stitspolyfiber.com and look for C2210.
They are both used for cleaning surfaces before painting. they remove wax and/or contaminants before painting. Be sure any product you use is completely evaporated before using the epoxy. Especially the Acetone. Acetone is a solvent for epoxies. Good luck Chip |
I have access to some automotive paint prep. Will this work?
Absolutely, it's the same stuff.
Thanks!!! I'll get started tonight.
Shawn |
| All times are GMT -8. The time now is 09:49 PM. |
