RCU Forums
-   Tips & Techniques (https://www.rcuniverse.com/forum/tips-techniques-180/)
-   -   Straws for wiring tubes? Oh yeah! (https://www.rcuniverse.com/forum/tips-techniques-180/6430544-straws-wiring-tubes-oh-yeah.html)
sscherin 09-30-2007 12:40 AM
1 Attachment(s)
I was looking for a small flexible piece of tubing to run servo wires through and I think I found it..
It's drinking straws.. Not just any straw will do.. The Double Big Gulp straw from 7-11 will do the trick..
They are 13" log and 5/16 OD.. When did straws get so big?
I like the straws for wiring tubes.. they are small enough to fit through most places in a wing.
Flexible so they will make mild turns and twists..
For this setup the tubes twist under and around one of the wing spars.. Try that with paper or cardboard tubes.
So on to the howto..
I needed about 15" tubes so I had to put 2 straws together..
It's an easy trick.. Just flair one straw with whatever you have laying around.. A punch did the job in this case.. Be ready to put the straws together quickly as it will shrink back to it's original shape fast.
Once they are in it holds together quite well.
After the straws were put together I used a forstner bit to drill holes in the ribs and run the tubes through..
Now for the wires.. remove the plug from one end of the servo lead, run them through the tubes and re-install the plugs.
That's all..
sscherin 09-30-2007 12:42 AM
RE: Straws for wiring tubes? Oh yeah!
1 Attachment(s)
Expanding the tubing
Am I the only one having BIG problems with attachments?
sscherin 09-30-2007 12:46 AM
1 Attachment(s)
One super long straw
Here's another
sscherin 09-30-2007 12:47 AM
1 Attachment(s)
Holes drilled and tubes installed.
sscherin 09-30-2007 12:48 AM
1 Attachment(s)
servo lead with plug removed..
sscherin 09-30-2007 12:51 AM
1 Attachment(s)
running the wires
Bad_Daddy 09-30-2007 05:34 AM
I always make a similar tube from the smaller stirring straws (like for coffee at 7-11) to run thru the wing or fuselage for the antenna wire on my 72mHz system.
jetmech05 09-30-2007 05:55 AM
the small coffee stirer makes a great antenna tube as well
John 38 09-30-2007 06:01 AM
I use small straws strung together (as above) to lace antenna wire thru and also for exits on closed loop controls
nedyob 10-01-2007 11:35 AM
They also make great servo wire looms inside the fuse when you want to clean up the inside to the fuse.
NEDYOB
Jazzy 10-01-2007 07:04 PM
Here is a good one:
The pick-up tube from spray bottles. The pick-up tubes for pump-type lotion, hair/body product dispensers are a little bigger in diameter but also work great.
These tubes can be used as anything from semi-flexible fuel tubing to pushrod guide tubes to antenna guides to water pick-up tubes (marine/boating). They also make a great hinge or axle bearing.
