RCU Forums
-   Tips & Techniques (https://www.rcuniverse.com/forum/tips-techniques-180/)
-   -   Aileron glitch (https://www.rcuniverse.com/forum/tips-techniques-180/7048247-aileron-glitch.html)
aatorix 02-09-2008 11:15 AM
Aileron glitch
Although in the hobby for years, this is my first gas build. Question ... My field friends tell me I should not have run a solid 4-40 rod from carb, past engine EIS ignition to servo because that will transmit EMI or noise to my receiver, which is a Futaba FM. I chose to stay with FM rather than go to PCM because I have never in 15 years or so had any problem what-so-ever with FM. I have set up a solid, no "slop", ball joint connected push rod that I really like. Must I change this to Nirod or Golden Rod to eliminate noise, or am I good to go ? I really like my set up, but..... Engine is a Fuji Imvac 43 on a giant Aeromaster bipe. Really nice... I have flown it three times so far.
Flyboy Dave 02-09-2008 12:11 PM
RE: Aileron glitch
....your friend might be right. The glitch is coming from somewhere. I would replace the
linkage with a Ny-rod and see if the glitch disappears. ;)
FBD.
Rodney 02-10-2008 10:16 AM
RE: Aileron glitch
If you have several flight already and no glitches, what is the question? It works so go with it. However, your friend is correct in saying that such a set up will be much more apt to cause problems than a non conductive push rod would cause. A far more probable cause of interferance is any metal to metal contacts that can vibrate or rub against each other.
