RCU Forums
-   Tips & Techniques (https://www.rcuniverse.com/forum/tips-techniques-180/)
-   -   Canopy Fabrication (https://www.rcuniverse.com/forum/tips-techniques-180/769375-canopy-fabrication.html)
tomb 05-13-2003 09:25 AM
Canopy Fabrication
Does anyone out there know how to make a canopy from scratch? Perhaps there have been articles in some of the modelling magazines. Does anyone have a reference?
My specific problem is that I am in the final building stages of a 120 inch wing span Schweitzer 1-26 and need a canopy. So far I haven't been able to find one that is large enough. If I cannot find a canopy that will work, I will have to make one myself. The alternative is to make it from a hollowed balsa block and then paint it.
CafeenMan 05-14-2003 12:05 AM
Canopy Fabrication
I take it you don't have a vacuum former or you wouldn't be asking this question. :)
The only way I know is to fake it. You carve a plug from balsa or another wood. Seal the wood well with multiple coats of lacquer or polyurethane. Let it dry for at least a week. You can put it in your oven to accelerate the drying, but the fumes won't make your next lasagna taste too good. :)
You could just leave it in the sun to bake as well.
Once it's dry, sand it smooth and wax it. Glue a dowel or two into the bottom of it and mount it on a board so that it's stable. the board should be big enough that it won't tip over when you pull the plastic over the form.
Next, build a frame to hold the plastic sheet. You can heat the plastic in the oven (carefully!) or get some friends with heat guns to help you out. Warm it up until it sags and immediately pull it over the form. Let it cool and pop it off.
Repeat until you get one that you like. It can take several attempts - especially if the canopy is deep or large. Good luck!
CAPtain232 05-14-2003 01:19 AM
Canopy Fabrication
He is right on the money........vacuum form it.
tomb 05-14-2003 10:12 AM
Canopy Fabrication
Thanks for your help.
I thought first of a vacuum former. The one that I have access to does not have capacity for the size canopy that I need.
What kind of plastic would be best for the canopy?
CafeenMan 05-14-2003 11:01 AM
Canopy Fabrication
typically it's butyrate.
