RCU Forums
-   Tips & Techniques (https://www.rcuniverse.com/forum/tips-techniques-180/)
-   -   Southern's Sorghum (https://www.rcuniverse.com/forum/tips-techniques-180/9638557-southerns-sorghum.html)
Naz44 04-05-2010 09:27 AM
Southern's Sorghum
Dear All,
i used Sothern's Sorghum in the past for faom core wings.
i have noticed that it is no longer avaialbe.
can someone give me another alternitive for foam core wings?
what other glue works as well and as easy to apply?
Dr1Driver 04-05-2010 09:42 AM
RE: Southern's Sorghum
Contact cement from HD, Lowe's, etc. Check it for compatibility first.
Walt Thyng 04-05-2010 10:09 AM
Did you check Dave Brown's web site? I seem o recall the he was the vendor.
Walt
Naz44 04-05-2010 10:14 AM
I checked Dave Browns website and he did not show it there.
i did send him an email and still waiting for his reply.
pmw 04-05-2010 10:20 AM
Gorilla glue or the Elmer's equivalent. (Forgot the name but it's the poly formula.) Both are foam friendly and work very well.
pitstop000 04-05-2010 11:41 AM
We had a thread on this over in the Classic Pattern Forum.
Don at Eureka Aircraft is now the dealer for Southern Sorghum
instead of Dave Brown as far as I heard last.
Give him a call, He’s a great guy to talk and deal with.
http://www.eurekaaircraft.com
Naz44 04-05-2010 11:52 AM
i talked to Don and he was great!!
he will have it avaialble inb a few weeks.
thanks for the help
pitstop000 04-05-2010 12:02 PM
No problem, Happy to of helped out.
This was the original thread.
http://www.rcuniverse.com/forum/m_91..._1/key_/tm.htm
KitBuilder 04-30-2010 04:13 PM
ORIGINAL: pmw
Gorilla glue expands during cure.. wouldn't this be bad for sheeting wings?? I too am needing someting for foam wings.
MIke
Edwin 04-30-2010 08:43 PM
I used pro bond. Similar or the same as gorilla glue. You dont put it on that thick. Works great, BUT, you have wipe off what oozes out to reduce your sanding. You just have to baby sit it for about 30 minutes.
Edwin
dhal22 04-30-2010 08:57 PM
i have done several wings with probond or gorilla glue. use a 3 or 4" foam roller and roll the glue on and spread it out until the foam is only wet. just a sheen or gloss, nothing more. mist your skins with water, assemble in the cores and either vacuum bag the assembly or clamp heavily between 3/4" plywood pieces. the foam will expand of course but into the foam. you will not find a stronger bond.
cpt nj 05-28-2010 02:13 PM
just a question almost pertaining to this subject , after you apply your adhesive to the foam and sheeting how do you keep it from peeling off
the airfoil while drying ?
Thanks NJ
landeck 05-28-2010 03:35 PM
I place the wing back in the cradle formed when hot wire cutting wing from the solid piece of foam. I place the cradles on both the top and bottom and add a lot of weight to the top. Then let it set over night.
Bruce
dhal22 05-29-2010 07:51 AM
you can also place the wings and shucks between 3/4" MDF pieces and clamp heavily.
