RCU Forums
-   Tips & Techniques (https://www.rcuniverse.com/forum/tips-techniques-180/)
-   -   Binding Jack (https://www.rcuniverse.com/forum/tips-techniques-180/9748917-binding-jack.html)
wannabflyboy 05-21-2010 06:37 AM
Binding Jack
If you have a plane that is frequently flown by others on 2.4, such as my 30% that I'm getting IMAC help with from another club member, instead of taking off the hatch and fighting with the wires on the TX, I plugged the battery into an unused channel and ran an extension from the battery jack to an externally mounted charge jack. Now I can simply insert the binding plug into the charge jack, bind and fly. Makes binding a snap.
BarracudaHockey 05-21-2010 08:40 AM
RE: Binding Jack
Yup, a 3 wire power switch does the same thing as well.
wannabflyboy 05-21-2010 10:42 AM
RE: Binding Jack
Hmm...never thought of that. Actually that sounds even better yet. I might just make that change.
BarracudaHockey 05-21-2010 01:51 PM
RE: Binding Jack
You can bind through the charge switch with a Spektrum/JR 3 wire switch harness as long as its plugged into the BATT/BIND port.
