Go Back  RCU Forums > Radios, Batteries, Clubhouse and more > Toy-Grade RC Products
Steering knuckle for Radio Shack 1:10? >
Toy-Grade RC Products Post in here about toy-grade rc products and the mods you''re making to them. These typically fall in the sub $100 range.
Old 03-21-2020, 12:23 PM
Default Steering knuckle for Radio Shack 1:10?
My kid found a Radio Shack 1:10 Silverado HD at Goodwill. It was intact but it's a push toy for him without a battery pack or radio. I would be interested in fixing it up if possible. The steel pin holding the wheel broke out of the plastic steering knuckle. I tried googling for parts but couldn't find any or even a whole truck as a spare.
I am not able to post pictures yet but can share if it helps explain what I am asking for.
Can anyone recommend a suitable repair or replacement?
Thank you.
Old 03-22-2020, 09:08 AM
Overvolted's Avatar
I have a couple Radio Shack models that share some of the same components, maybe you can find another similar. Could repair the knuckle if you have it all. A pic would help.
Tiogaplanet (03-22-2020)
Old 03-22-2020, 11:56 AM
Thank you for the reply. I tried to pm you with the pics. Not sure if it worked.
Old 03-23-2020, 06:05 AM
Overvolted's Avatar
The pics did not work.
Old 03-23-2020, 06:11 AM
Overvolted's Avatar
Ok, so I was able to see the pictures. The knuckle looks intact except for the spindle the wheel goes on. Is that all your missing? Is there a crack in the knuckle where the spindle goes through? Tough to see in the pic. Can you post a pic of the other side for reference? If all you need is the spindle and a nut it shouldnt bee too hard to find something.
Old 03-23-2020, 06:18 AM
Overvolted's Avatar
Im a new member too and I cant post pics yet either. Search Traxxas Cat steering arm, it has a removable spindle that might work. If you can measure your other side I can measure mine andvsee how close it is.
Old 03-24-2020, 04:03 AM
Overvolted , I really appreciate your help. Seems like the days of a ten post minimum to post pictures should be behind us by now. Anyway, I sent you a pic of the intact knuckle. The spindle looks like it's a press-in job - no nut. The broken knuckle is split and the spindle was lost when it happened.
I would have to disassemble the the intact side to get a measurement. Would a measurement of the plastic on the broken side help any?
I would be willing to replace the whole steering assembly with something compatible if it comes to that.
Old 03-24-2020, 06:35 AM
Overvolted's Avatar
Alright!!! I can now post pics!!! Im thinking something like this spindle here and using a nut to hold the wheel on. You could epoxy the cracked nuckle after the spindle was installed for some strength. I think you could also get creative and replace the whole knuckle as well, of course you may have to do both sides. You may need a donor car/truck for the parts perhaps also from goodwill to keep the cost down. Gotta keep in mind a radio,esc and battery is gonna get you around $30.00 or so. Ive done a few of these builds and give them to my kids to play with and when they kill them I pull the electronics out and put them in anotherone. To me its fun taking trash and making a cool toy for us to bash on the cheap plus ive honed my skills to make some really cool builds and upgrades to my other cars.
Old 03-24-2020, 02:09 PM
Overvolted , congrats on being able to post! That's great news for you. Where did that spindle come from? Your idea may work but I'll have to take some measurements on the spindle I have left. I have considered replacing both knuckles. If I had a lathe I'm sure I could do it. Thirty bucks sounds reasonable for what you're describing.
Old 03-24-2020, 02:24 PM
Overvolted's Avatar
Thank you. It is nice to be able to post pictures as it helps a lot. The spindle/arm is from my Radio Shack Golden Arrow. I think you could find something like this or similar and make it work. Strengthing that knuckle will be the priority though so it wont come apart again. Looking at your pictures and it seems like if you had to replace the knuckle it would not be too bad. You almost have a flat solid plane top and bottom of where the knuckle mounts. Ill dig through my spares bins when I get home and see if I have anything for more ideas.
Old 03-30-2020, 02:05 PM
I got lucky today! Had a cigar and decided to sit where my son said he broke the truck. Lo and behold I found the spindle that busted out of the knuckle. It was sitting there, nicely blended by surface rust into a camouflage with the fallen leaves. If it wasn't for the patience a cigar imparts I may not have found it. Now to fix it with some plastic epoxy. Can't wait to reach ten posts to share my progress. I also cleaned up the chassis and repaired a broken body mount.
Old 03-30-2020, 08:40 PM
Overvolted's Avatar
Wow, id go by a lottery ticket as well!! Thats great you found it. Now to get it back on and run it. Good luck with the repair and post up pics of it when you can.
Old 04-09-2020, 05:48 AM
I still can't post pictures but I am happy to report that I repaired the knuckle. After a good cleaning of the spindle and the plastic knuckle, I super-glued it all together and used clamps to hold it together while it cured overnight.
I inspected the receiver in the truck and it was physically damaged in the form of pulled-up solder joints and traces. I didn't even try to test it or fix it. I am missing the radio so that was a gating factor. I pulled the receiver from an ultra cheap car my son had. I swapped in the receiver and tested that everything works. The donor receiver does not drive the motor very well and the truck lumbers around weakly. Otherwise, it seems like the steering and drive motors both work.
I noticed an odd thing while disassembling and cleaning - the steering assembly has seven wires attached. Two are for power and with a little inspection and googling I found that the other five wires are used for detecting the position of the steering arm. I thought about doing using an Arduino to do something with those lines before I decided to just pump the metaphorical brakes.
I've purchased three Traxxas Rustler chassis. I've decided to build one for myself and two for my kids. I have put this toy grade truck on a shelf and I'll come back to later.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
