(BLACK-FLY) 1/10 NEWBRIGHT..VIDEO
The fly that stings.[:@][:@][:@][:@]
BLACK-FLY .. A large rock in the face .. Just for fun ..
At that time, I have a small camera .. So .. short video
[youtube]http://www.youtube.com/watch?v=N07ij1bGBGA[/youtube]
RE: BLACK-FLY ((VIDEO)) The fly is here.
HELLO ...
The ancestor of YELLOW-CRAWLER .. ((BLACK-FLY))
[youtube]http://www.youtube.com/watch?v=N4fGA9EZ_Bs[/youtube]
Before, YELLOW-CRAWLER, I perfected the 4 th gear on ((BLACK-FLY)) .. and on the track ..
The train was already past .. [8D][8D]
Here in the woods, we have black fly ..
RE: (BLACK-FLY) 1/10 NEWBRIGHT..VIDEO
19160-R MOTOR,DC,6-12V,9000RPM,0.6A 46.6G-CM,4.3W,SHFT 02X8mm
http://www.jameco.com/webapp/wcs/stores/servlet/Product...001&productId=232005
ORIGINAL: mark1andy2
if i get a bigger motor will my newbright have more power than just putting in the fourth gear mod?
Never ..
To have the power to YELLOW-CRAWLER, you should install this 4 th gear ..
There is no other solution .. A stronger motor, will not allow you to climb on the rock ..
It will make your crawler, just a little harder ..
yaleforscale .. BLACK-FLY, is a product NEWBRIGHT ..
I loved making his body .. I wanted a body out of the ordinary ..
This was the first hood, that I drill for my long shock ..
When I started in this area r / c ..
yaleforscale .. thank ..
I will perhaps make this model one day ..
I only have to buy a body of Rubicon, and it will be done ..
more I think about it, more I think ..
how do i find the HIGHER TORQUE GEARS FOR NEWBRIGHTS. Also is it ; the bigger the gear; the more torque. or is it the other way around.
Banned
COBRA65 .. said ..
Hi Adrian,I have used different size compound gears for the 4th gear mod with good results,the only thing that changes is your final drive ratio.
46x10 10t pinion=199 to 1
46x10 8t pinion=248to1
42x14 10t pinion=130 to1
42x14 8t pinion=162 to 1
56x10 10t pinion=242 to 1
56x10 8t pinion=302 to 1
Hope this helps a little
Joe
TEXX said .. 34x10 8t pinion=184 to 1 =YELLOW-CRAWLER
Stock motor .. Stock tires .. Stock electronics .. Stock servo steering motor ..
Joe
