ok what is it then
ok what is it then
ok the manual says 15T motor or higher and the Box says 15T limit
[link=http://h1072623.hobbyshopnow.com/products/description.asp?prod=DYN4925]ESC[/link]
so help me because i have just bought my Venom Creeper and i just need a more i have a 15T Fireball order but i can always cancel it and order the motor the the truck needs is a 55T mod fireball rock crawler
RE: ok what is it then
the 15turn limit means no LESS than 15 turn motor. it doesnt mean that you cant use a higher turn motor. higher turn motors draw less amps. the lower turn motors draw more, and thus require a better esc. the tazer should be fine for a high turn motor.
