Toy-Grade RC Products Post in here about toy-grade rc products and the mods you''re making to them. These typically fall in the sub $100 range.
1/14 RC Car Rebuild
Old 07-18-2010, 01:18 PM
Ronaldo95163
Ronaldo95163's Avatar
Default 1/14 RC Car Rebuild
Hey guys i got a 1:14 Scale 350z had it for some time, like about 4-5 years and it still works awesome! however i decided to kinda rebuild it.
Here are some pics of the Lights I installed:
I used:
Two Blue LED Lights
1 Toggle Switch
9V Battery
Battery Connector
High Temp Red Silicon
BTW anyone knows where i can get a 40mhz controller since the steering on the controller has like a metal thing in it that rubs on a metal surface which enables it to turn left and right, sadly the the metal thing in the controller has started cutting into the metal surface any help would be appreciated.
More Mods to come!
Now with lights on:
will be getting new parts soon i have to clean out the gearbox after all that dust and stuff got in and is giving the motor a hard time to turn the gears
I found a 1/14 RC car motor idk if it will work up with my car, for some reason they had no description on it
Found A Pair of Front Racing Tires
Pair Of Rear Racing Tires Also
My tires got old, they seemed to have gotten a bit stretched out and the rims begin to slip inside it.
Found a cooling fan also:
Found the Racing motor
I Also need help with the transmitter
This is what it looks like:
http://www.snuffledopple.com/remote-contro...de44c15b593e384
It seems almost impossible to fix, i wish i could continue using it but sadly the steering and throttle has begun to stick when ever it is turned or pulled
Anyone have any ideas of what i can do to overcome this problem, i cant even find a 40mhz transmitter online.
And about the motor anyone knows if 380 size motors work with 1/14 rc cars, i mean the name of it is a 1/14 motor but im not sure if it will fit in my car since the motor is in an enclosed area as u can see in the pictures provided above
BTW will this motor work ?
It's a 370 Motor 8T
These are some pics of when i disassembled the car, i was looking for the receiver just in case i have to change it if i were to get a new Radio but sadly its built in on the circuit.
The Servo:
In case images are too big these are original links:
http://pwimage.org/images/btzl24403vscpu92wqbr.jpg"]http://pwimage.org/images/btzl24403vscpu92wqbr.jpg
http://pwimage.org/images/s5npj0kizqhroi13usng.jpg"]http://pwimage.org/images/s5npj0kizqhroi13usng.jpg
http://pwimage.org/images/9y2qlb43hoawvaiobke.jpg"]http://pwimage.org/images/9y2qlb43hoawvaiobke.jpg]
Old 07-19-2010, 07:41 AM
Ronaldo95163
Default RE: 1/14 RC Car Rebuild
any ideas of wht ESC, motor and receiver i should get? im considering gutting out the car
Old 07-19-2010, 10:28 PM
Ronaldo95163
any ideas? for motor, receiver, esc and transmitter??
