i need more
ok i need more torque for my New Bright Toyota FJ Cruiser to get in mud
RE: i need more
ORIGINAL: rcToyotaman ok i need more torque for my New Bright Toyota FJ Cruiser to get in mud |
RE: i need more
<div id="result_box" dir="ltr" style="text-align: left">Are you ready to make the installation of the 4 th gears ? .... as other members have done ..http://www.rcuniverse.com/forum/js/f...ey/msn/eek.gif
<div id="result_box" dir="ltr" style="text-align: left">Have you read some thread that discusses this topic ????????????</div> For example, ... ((((( The thread. <span style="color: #ff0000"><span style="font-size: larger">YOUR THREAD</span>... </span>((what gear mod 4/13/2009)) of<span style="font-size: larger"> <span style="color: #ff6600">rcToyotaman</span></span> ))))). HA HA HAhttp://www.rcuniverse.com/forum/js/f...sn/biggrin.gifhttp://www.rcuniverse.com/forum/js/f...sn/biggrin.gifhttp://www.rcuniverse.com/forum/js/f...sn/biggrin.gif The thread ....(New FJ Cruiser Bright 4/30/2009) of creepy crawler .. The thread ....(gear mod 4/4/2009) of mark1andy2 .. ((( A <span style="font-size: larger"><span style="color: #ff0000">decision </span></span>and <span style="color: #ff0000">actions ...</span>on your part would be nice ..http://www.rcuniverse.com/forum/js/f...sn/biggrin.gifhttp://www.rcuniverse.com/forum/js/f...sn/biggrin.gif</div> |
RE: i need more
Have you tried overvolting the motors by replacing your battery with one of a higher voltage?
RE: i need more
like a 18V battery ?
RE: i need more
ORIGINAL: rcToyotaman like a 18V battery ? 7.2VDC to 9.6VDC 9.6VDC to 12VDC Otherwise, you'll fry your ESC and nothing will work. This gives the motor extra juice as a motor will drop voltage across a battery like a rock. By supplying the motor with extra voltage, it will offset the drop and allow the motor to work at its peak level constantly. For example, when you gun the throttle, the ampherage load placed on a 9.6VDC battery will drop the voltage being supplied by the battery down to between 7-8VDC. By upping the voltage to 12.0VDC, that loss will be offset, thereby taking the 12.0VDC battery and having it output between 9-10VDC the motor should really be running at. Remember, on your car you have an alternator to return current to the battery so you don't see a voltage drop when it's running... voltage drops only when the car is being started, thus your Cold Cranking Amp rating on the battery. These units do not have alternators to return a flow to the battery, so the batteries are in a constant state of drainage. |
RE: i need more
i was think of making a alternator
RE: i need more
Now that would be interesting, but i don;t think it would work.
RE: i need more
Me either... I don't think you'll have enough force to turn a magneto. If you need help in modding the battery specs on a New Bright, check out the first few pages of my Monster Car/Monster Truck posting.
