Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
trainer cord on 7c
Old 03-12-2004 | 11:28 PM
Default trainer cord on 7c
i have a 7c and want to use it on an older 4 ch radio. the guy at the store said it would work. so i follow the directions, but when i flip the trainer switch on the 7c the 4c doesn't take over.. but if i do it the other way. the 4c acts as the master no problem and the 7c works as the slave. Could my trainer button on my 7c be broken?
Old 03-16-2004 | 10:31 AM
Default RE: trainer cord on 7c
Hi Joe123s,
If you have the older blue lettered 4VF or a 4NBF, the first run of 6EXA's when used as master will make your servos chatter. Since the first run of these 6EXA's there have been no problems with older radios. You will see an FAQ on our website regarding an update that we do at no charge on first run 6EXA's for this problem.
If you are getting no repsonse at all, I would suspect either the trainer switch on the 6EXA or the trainer cord itself as being the problem.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (http://www.futaba-rc.com)
Old 03-17-2004 | 03:35 PM
the problem is that the 7cap isn't compatible with the conquest. we tried it at the hobby shop and he brought put a newer box and it worked fine. so thats the problem. if anyone else has that problem see if they are using a conquest
Old 03-18-2004 | 12:27 PM
Hi Joe123s,
Which of the Conquest series are you trying this with?
Krysta
Old 03-19-2004 | 03:10 PM
fp-t4nbf
Old 03-19-2004 | 03:13 PM
Hi Joe123s,
Since it is the 4NBF that I mentioned earlier, I would say the 6EXA is one of the first run radios that we received.
I would recommend that you send it in to us to be repaired under warranty.
Thanks, Krysta
Old 03-19-2004 | 03:28 PM
what are you taling about the 6exa? i have a 7 cap
Old 03-25-2004 | 10:58 AM
Hi Joe123s,
Please excuse me, "oldtimers" seems to be creeping up on me!
As I am writing this to you, we have people who are looking into this for us. As soon as I hear back, I will let you know what they have found out and let you know immediately.
Thanks, Krysta
Old 03-30-2004 | 11:35 AM
HI Joe123s,
We have had some testing going on here the last few days on the problem that you are seeing with the 7C and various student radios.
Some very old units, made before 1997 are just not compatible with current technology. The 7C will work fine with any Futaba radio made after 1997, there is no need for any modifications to the 7C. If you do not have another transmitter to use as a student other than the Conquest, you can send the Conquest into our service center and we can modify this so that it will work with your 7C for you.
Thanks, Krysta
Old 03-30-2004 | 03:20 PM
thanks. i do have a newer one that im going to use. i just returned my cord and got a differnet one. i hope this thread could help others.
