Stampede how to lower and widen
Hello
I have an original model Electric stampede.
i want to lower it a bit and make the wheelbase wider.
A friend recommended that I buy this proline Protrac suspension kit for the SLASH, and use it on my stampede:
http://www3.towerhobbies.com/cgi-bin...&I=LXYWS9&P=ML
can anyone suggest a cheaper solution that will give me the ability to set my suspension height to a few different heights, since the stock shock towers only have one shock mount hole,,, and a way to make my wheelbase wider, all while reducing my wheel wobble??
my wheels also have bad wobble, which, I was told by my buddy, the proline protract kit will fix too...
I just dont know if I want to spend $56 ...
Any thoughts?
Any thoughts?
RE: Stampede how to lower and widen
hi nitrostam
I have proline 3.2" badlands and some proline 2.2" holeshot tires I run with it..
but i'd like to make the truck wider.. any ideas how?
I want to widen it to help improve handling and stability..
i put Axial oversize rims and oversize Terrarizer tires on my Emaxx and it made my emaxx 2 inches wider and improved stability and handling tremendously. the stampede loves to tip over on a turn or hell even when hitting a bump!
so i am hoping by widening it,, it will help this issue
http://www.rcuniverse.com/forum/m_1999148/tm.htm
read the last few post. Ericg2000 lowered and widened his pede, looks good too!
