View Poll Results: sensored or sensorless
sensored
1
100.00%
sensorless
0
0%
Multiple Choice Poll. Voters: 1. You may not vote on this poll
pros and cons of sensored vrs sensorless on a 1/10 summit
ok,still kinda a noob on the technical side of things. so when in doubt, rely on experienced people.
set up is a bone stock summit 1/10.
current spur is 65t
stock diffs- i want to retain the T-lock feature
tires have been upgraded to the TRENCHERS
tossing up between a CC 2200kv/MM set up, or the ever popular RX8 set up.
mostly will be used for loose dirt bashing,but a good bit of rock crawling..........
experience with my E Revo says the CC set up will be glitchy and jumpy when trying to crawl.
if swap to a tekin set up,will that affect transmitter,reciever set up?
any help will be greatly appreciated............. never dealt with a sensored set up before
current spur is 65t
my main goals in the upgrade is purely just a bit more controllable power. mainly for the larger,heavier wheels then what came stock. if i leave stock set up i know with in time the added strain on the motor will burn something up. im not wanting to take a summit and make it a revo, i have a revo for the speed. im looking for just a little more turning power for the hard climbs mainly. i know with my brushless revo,trying to go slow when trying something technical can be a challenge,wants to lurch and jump. thats my only hang up on the CC combo. have a spare set setting in tool box as we speak.
from what little i have found in researching thinking its a fairly simple jump from sensorless to sensored.. picked the RX8 from pure popularity acrost the forum boards have read. seems to be reliable. but also open to other suggestions.
yeah,still doing alot of reading up on them, but looking like going to be 1800-2050kv. the weight is another issue got to work on,mainly trying to proportion it correctly so not to lean to one corner too much
