Revo 3.3 reverse problem
Hi guys.
I have an issue with my Revo 3.3 and was wondering if you good people can help me out.
When I shift into reverse or forward, truck continues as if it hadn’t shifted but after a few throttle blips it finally changes direction.
Its weird, shift servo works, and when I shift with truck not running its shifting properly it seems when I pull the truck by hand.
I tried another gbox sensor and optidrive, no luck. Calibrating optidrive also did not work. Different trasmitter gun, no go.
I have another Revo so changing parts over is not an issue.
Any ideas?
Any ideas?
The gears need to mesh up after shifting, so a little bit of throttle will rotate the gears until they engage.
Also if your idle is too high it might make it hard to get into reverse.
