Os .21tm in trx revo
I just reached full break-in on my OS .21TM in TRX REVO.
My problem is I've tuned HSN and LSN for max performance and cannot get Max RPM and Wheelies like I've seen on many YouTube Videos.
I am at the point of not knowing what to do.
Any help would be greatly appreciated!!!
The pipe is stock pipe from Traxxas Revo...
The Manifold came with engine...
What pipe and manifold are you using? What fuel and glow plug? What gearing is it set up with?
Just for what it’s worth, the OS .21TM doesn’t have that much more power than a 3.3 Traxxas engine does. It should wheelie, however. It might just need a gear change.
Fuel Bones Brew 20% 12%Oil...
Get rid of the LC3 plug - it’s a hot plug. You want a medium heat plug. O’Donnell’s purple medium long reach or a McCoy MC8 are good medium plugs. A Novarossi C6S or C6G is a great plug too.
Next, I’d drop the Traxxas pipe and get a better pipe. If you have the high rpm dual chamber resonator, you’re good for the most part. Just drill the stinger out. If it’s the single chamber, get the two-chamber at the very least.
Lastly, change your spur gear or clutchbell - the spur gear is the cheaper option. Try a smaller clutchbell or bigger spur gear.
If your truck is setup the same as the others you’ve seen and yours isn’t doing what theirs does, then your tuning isn’t right.
Thank you for help!! I will do your recommendations. The pipe is a dual chamber pipe. The videos I've seen show Revo wheeling with the same pipe.
Again Thank You for your help!!
The glow plug change won’t make a dramatic difference, but will allow you to eek a little more power out of it. Same with drilling the stinger out.
I think either it’s geared too high (for speed) or you don’t have it tuned quite right, or both.
