t-maxx trans sound?
t-maxx trans sound?
I have a tmaxx with 1 1/2 gallons in it and the traney makes a clacking sound when the truck is moveing. it is not to load and I cant hear it when the truck is running. dos anyone also have this? BTW 1/2 gallon has been with a .18tm, but it made the sound before I got the 18
RE: t-maxx trans sound?
ORIGINAL: oc off road
You might want to check your clutch.
ORIGINAL: BlackFox
Does it do it at idle? If so my truck does that if the idle is set too high
FL
Is your truck jerking slightly while idle? If so you may just be idling too high and engaging the tranny.
Do you still have reverse? If so maybe your reverse servo is not engaging forward properly?
AB, CANADA
I mean the spur gear will spin at idle.
Im honestly not to sure what the clicking sound could be however, I know that when my Clutch Shoe spring on my Max went, the shoes flopped around in the Bell when I would just push the truck.
ME
might wanna put in new clutchbell bearings they might be seizing and causeing this prob with the spur gear turning. the clicking is it only when you first take off
The sound comes from the trany, and no were else. do I need to oli the trany? it dos not make the sound when idleing only when the weels are moveing.
