Engine screaming LOUD!
Well, i was bashing with my revo which got a sirio 0.18 engine. The servo battery was low but still i just wan to continue bashing, suddenly I was at WOT and lost the control of it, it was running like hell engine sound was yelling to heaven and Pufffff, got hit with the concrete fence, my truck was lifted over and the engine continue to rev up so high for around 10-15 seconds that my wife could hear the engine on her apartment (10th floor), anyway, run and manage to turn it off by the exhaust but when i pressed my finger on the exhaust i also noticed that a lot of unburning fuel was coming out through the exhaust. Well, broke right a-arms, rims, shock mount, bulkhead. however, is my engine still good? did it affect the engine in anyway? my engine is new and does not have 1/4 of gallon on it.
RE: Engine screaming LOUD!
check compression of the engine it should be all right had a run away with my axis and a torq 21 and simular situation, the only think mine the exhaust was knocked off the rear so had to use my shoe over the exhaust port to stop and i had mine run up to very high for almost 30 sec
Another thing, when hit the fence the spur gear stripped and the engine was at WOT without engaging the spur, this made the engine revs very high.
I have checked the compression and looks O.K. However, when i turn the dif to the other side it should be locked, and in this case it does turn.
i had my old t-maxx do that with my 2.5 problem was that the throttle was stuck open so my glowplug warmer was still in it it went over the curb and up a tree did a back flip and snapped my glow plug warmer now i have a traxxas revo its a lot better im going to upgrade the motor but i dont know what kind i should get any of u have a suggestion that would help ive herd bad thongs about the rb323 and i was wondering about the 3.3
ORIGINAL: hibrahim001
Then you most likely killed the connecting rod. Before you run it again I strongly suggest you take the engine apart and examine it closely.
FL
ORIGINAL: jasonx9
my 3.3 is running great
storng moter good torq
picco .26 max makes the Revo an absolute ANIMAL!!!!!! Cant hardly control it. I dont have one but I drove my friends and it is amazing how much faster and more quick than my revo! I cant wait to get one actually.
