paint on chassis
GA
RE: paint on chassis
I had pretty good luck removing the color using a product called Grease Lightning. I soaked the plate in the stuff and it came right off. Then I polished it to a shine.
FL
Oven cleaner works but you have to be good on the timing or else it gets dark
NB, CANADA
1 Post
I used a jitterbug sander (random orbital sander) to do mine... took almost zero effort to get the blue off. I could keep at it and polish it down to a mirror finish, but it will just be getting scratched up on the first run anyways...
KS
i've heard of using oven cleaner also, but i have'nt done it and don't know the details. spray paint would be ok, unless you want a bare aluminum finish
yea this will do it.. go to the cleaning section in a food store or somethin. check out the rest of the stuff on this site to cuz it all works
http://www.rcbros.com/forum/forum_posts.asp?TID=801
Yes the alluminum does go dull but thats why at the bottom of my link it shows you to polish it and what it looks like before and after..
KS
spray it with a coat of clear after it's polished. once you have all the stuff attached to it, you can't see that much of it anyway. and if you worry about paint chips and keep your truck spotless, then it won't take you very long to re-sand and reclear it when you have it all stripped for cleaning!
Yea 89ram, car wax will repel a lot of garbage you throw at your truck. If you look on the link theres other ways to keep your truck clean(or at least a safe way without damaging electronics).
