Traxxas Monster Truck forum Discuss the Traxxas T-Maxx, E-Maxx, Super-Maxx and all other Traxxas monster trucks in this forum. You may also optionally discuss them in our MT general discussion forum.
Slow acceleration
Old 06-03-2007, 07:06 PM
PhatMan
Default Slow acceleration
Hey guys I have a question when I pull the throttle trigger the tmaxx is kinda jumpy (kinda jerks at start) at first and it sounds kinda grindy but once it takes off its fine? Does anyone know what the problem might be thanks Phatman
Old 06-03-2007, 07:10 PM
Muggy250r
Muggy250r's Avatar
Default RE: Slow acceleration
to rich lean it out just a little
Old 06-03-2007, 07:12 PM
pinky2252s
to back up that statment little rich on the low end
Old 06-03-2007, 08:54 PM
PhatMan
I trust you guys but i think somthin is wrong with the tranny it runs great but I can here the gears kinda but i have the right spacing but it jerks the tranny does not the motor.
Old 06-03-2007, 08:58 PM
Toxik
Check the gear mesh from the clutch bell to the spur gear. If it it grinding there, then you need to re-adjust by moving the motor mount down a bit. While your doing that check to see if the spur gear is not stripped from the grinding. If that isn't it you will probably have to check inside the tranny. GL
Old 06-03-2007, 09:12 PM
rcnitrohead
rcnitrohead's Avatar
Ok first off with the jerking, it could be hesitating from a lean condition so richen the LSN and HSN 1/4 for a start. If your motor is in tune, its normal for the T-maxx to jerk a bit (from 0-5mph) becuase the transmission needs to engage fully before it works properly. It should not have a grinding noise, if it does it sounds like a drivetrain problem. This could be but is not limited to stripped diff gears, tranny gears, stripped spur, or brake binding. Those are the biggest weak points in the driveline that could be emitting such a sound. Hope this helps
Old 06-03-2007, 09:39 PM
pinky2252s
dude seriosly do you have to be mean truths?
Old 06-03-2007, 09:55 PM
IOWAREVO
IOWAREVO's Avatar
.....nvm[:'(]
Old 06-03-2007, 09:58 PM
pinky2252s
are you talking to me?
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
