AHHHHH
AHHHHH
Hey everyone alright this is the update on my T maxx... lol it now starts and only stays running as long as im holding down the ez start button what do you think the problem is? My easy start gets so hot and is just killing my battery every 15-20 minutes, but the engine turns over and I can rev it as long as im holding the easy start button down, as soon as I pull it out and give it gas barrappp dead...any suggestions? im running a mccoy mc 9 glow plug, I take the temp and it only gets up to like 107-114 range...
NC
RE: AHHHHH
Try a fresh glow plug even if you just put one in. Mine did that today actually and I just put in a new glow plug and it ran fine.
Maybe lean it out also if that is really what your temps are. Its probably getting way to much fuel and only running when the plug is hooked up. Another words that is why it is shuting off when you release the button.
RE: AHHHHH
alright hopefully thats the problem, the plug light comes on and everything, but I guess it could just be coming on because the easy start is igniting it considering there is no light when the easy start is plugged in...obviously lol
KY
RE: AHHHHH
Did you try going back to stock settings? You should be just about flush on the low speed (located on the carb slide) and I think 4 turns out on the high speed from closed. The idle gap is sorta tough to just throw out there, I kinda just learned to eye ball it and been lucky enough I am usually dead on within +/- 1/8 turn. Probably about the thickness of a quarter or so I guess would be a good approximation.
RE: AHHHHH
yeah Ive been working on my truck all day every day since thursday and finally got it to start...now im tryint to tune it like I said and its fustrating the hell out of me lol but Im going to hang in there, I am going to pick up some zip ties tommorow and take off the stock air intake and replace it with an engine saver, any you guys recomend? also what glow plug do you recomend for running the 30% nitro from traxxas...or the 33 I should say!!
RE: AHHHHH
ORIGINAL: socalsuperbike
If it screams-dies down-screams again its too lean, if its running at 280+ its too lean, if it seems wildly faster than you've ever seen it before... Its probably too lean, check temps all the time.
Thats the best advice I can give, good luck!!
