HSN assembly Q...
CA
HSN assembly Q...
hi i was wondering, is there a special way to install the fuel inlet to the brass HSN mount? there are 2 holes on either side of the brass mount where you place the fuel nipple. is the fuel nipple suppose to line up with one of the holes or is it alright to leave it where theres no holes?..i was thinking that if you line it up, the fuel would have easier flow through the HSN?
My Feedback: (22)
TX
RE: HSN assembly Q...
Thats a banjo fitting. Orientation of the internal holes are irrelevant. Adjust the black fuel inlet so that it's where you want it, then tighten down the brass HSN base. Be sure not to overtighten it!
CA
ORIGINAL: Traxxas_Tech
My Feedback: (22)
TX
"Thats a banjo fitting. Orientation of the internal holes are irrelevant. "
That means it doesn't matter where the holes are on the inside... What do I need to clarify?
ORIGINAL: Danju
yeah whats the banjo part?
the little black ring with a stick (the bit that the fuel pipe fits to) lol
or the bit that looks like a banjo lol
