Traxxas Monster Truck forum Discuss the Traxxas T-Maxx, E-Maxx, Super-Maxx and all other Traxxas monster trucks in this forum. You may also optionally discuss them in our MT general discussion forum.
servo troubles
Old 11-24-2007, 02:25 PM
tmaxxman1212
Default servo troubles
i was going to drive my t maxx after i fixed it and i wanted to make sure everything worked, i go to test the steering and it didnt steer, i figured its the stock servo it might be a little weak so i changed the batteries...still nothing so i lift the front end up and it still didnt steer...any ideas????
thank you
Old 11-24-2007, 02:37 PM
Clymer122693
Default RE: servo troubles
are they plugged in? if so put them in a different port and try it might be the rx
Old 11-24-2007, 02:40 PM
tmaxx_man87
if the servo is working (you can hear it) did you tighten the axle carriers? maybe you got them to tight and they wont pivit...
Old 11-24-2007, 06:15 PM
tmaxxman1212
instead of moving side to side it will kind move up and down...i check and yes the servo is working properly
Old 11-24-2007, 06:36 PM
tmaxx_man87
just move the tires by hand and see if everything is free?? and go from there... maybe the servo saver is bad..
Old 11-25-2007, 12:09 AM
bob5429
loosen the caps on the a-arm (the one that uses the bigger allen key)
