Pivot Balls
FL
RE: Pivot Balls
I also broke my upper a-arm. I did take it out of the lower a-arm and tried to force it in but it feels like I'm going to break or bend something...
RE: Pivot Balls
If you take the big hex screw out of the front and the pivot ball screw cdoes not pop or push in easy, then use a small socket on the back of the knuckle as a spacer and put the pivot ball in the front and slowly and carefully close your vice. The socket will act as a stand off spacre to allow you to push it into the housing. The threaded part of the pivot ball will push in through the socket.
FL
RE: Pivot Balls
Nobody has a solution to this? The vise didn't work because the angled design of the ball housing makes it impossible to keep the ball angled correctly, it just goes flying.
RE: Pivot Balls
Just take that weird plastic triangle tool that the revo comes with and take off the pivot ball caps. Then just unscrew the pivot ball from the a-arm, and put it through the axle carrier back into the a-arm. Then just tighten the pivot ball cap down and turn it back about 1/2 a turn. It took me a while to figure it out too when I first tried it.
FL
RE: Pivot Balls
Oh ok. I'll see if I still have that triangle tool. Anyone have a pic of it because I don't believe I have anything triangular (I bought used...).
RE: Pivot Balls
This is what you need.
http://www.amainhobbies.com/product_...ducts_id/19123
You have to use the bottom side to unscrew the pivot ball caps.
RE: Pivot Balls
ORIGINAL: Soppy
I hit a wall and my pivot ball popped off... How do I put it back into the ball carrier?
FL
RE: Pivot Balls
No it didn't for some reason. Guess I got lucky. I know what your talking about with the tool now. I'll let you all know how I get on once I get back to my house Sunday night.
FL
RE: Pivot Balls
ORIGINAL: Gustaf4096
Just curious did the ball carrier not break?
ORIGINAL: Soppy
It is all part of the Fun
P.S. Chillin With my bro tonight, we fixed the pivot ball no problem!
