e-revo questions
MN
would a spektrum SR3000 reciver work in a e-revo? i am asking because the e-revo uses 2 sevros for the steering. also i am putting in a novak hv maxx 6.5 motor in it. what size pinion should i buy for it? and what other upgrades should i buy for it for hard bashing?
thanks
thanks
MI
It will work, but you need a Y-harness. Also, it depends which TX you have - I believe that the DX3R allows you to mix channel one and three so that you could run two servos for steering, in which case you wouldn't need a y-harness. I don't know if the 3S does and I am pretty sure that the 3.0 doesn't, but that is all off the top of my head so consult your manual.
What you should really do is pull out both servos and add one powerful digital servo. In the case of steering servos one is better than two (assuming no loss of torque).
