traxxas top fuel
NJ
RE: traxxas top fuel
It has a VERY high oil content. Because of all the oil it tends to be hard to tune. I had issues with Top Fuel and got away from it. I'm happier for it and my Revo runs better with 12 % oil instead of 20 %.
TX
ORIGINAL: nargargle
WHAT FUEL DO YOU USE?
I use top fuel 20% and have not had any trouble with it. Tuning is not hard with it either. I live in south Texas so i guess the extra oil keeps the temps cooler. I like the extra oil. bigger tuning window. I have used odonnels but top fuel is easily available. I also like the blue color, easy to see the fuel in the tank.
CA
I have been using Powermaster 5% fuel with 18% oil. I find it easy to tune and no noticeable power loss. I can still lift the front up on command with a 3.3 Revo. And it's cheap at 14 a gallon at my LHS. Have been through 4 gallons so far with great results.
TX
one thing about traxxas fuel is that its will run lean with no sighs of it. that is untill you check the temp..the tunning window is too big. so it hard to tell when its just right...i use odonnel and really like it... i only have to touch the needles a few times in a 4 hour bash session. and there small changes to compensate for weather or ambit air tempeture changes..... ...imo the traxxas engines suck...i can never get that perfect tune on them...they will run but i cant get it perfect.
David- You are using airplane fuel, that much oil in our car engines will only make your performance drop and make engine responsiveness worse. The ideal oil range is 8%-12%, anything more and its crap. Most of the people who praise Traxxas fuel haven't run anything better, guess they will need to figure it out for yourselves. There is no comparison between a fuel like Byron's and O'Donnell's vs Top Fuel..
CA
agreed... I would also like to ad that low nitro and high oil content fuels have a narrow tuning window. May be a negative for some, but I however, like it. For me it's easy to know when the engine is out of tune. based on my experience with nitros I also found that traxxas engines are harder to tune than most others. To me, they seem to have a narrower tuning window and don't like to idle well if settings are a little rich. When tuned right the 3.3 will produce good power and stay under 270.
CA
ORIGINAL: rcnitrohead
NJ
I've been running Trinity Monster 20% with 12% oil with excellent results. Very easy to tune and holds as well as can be asked for New Jersey weather. I even take my Revo to work with me and have to do very little tuning in the morning or during lunch.
TX
well, airplane engine run alot differnt then car motors....the car motors are fast reving hight rpm motors...while airplane motors are just the opposite. so they make the fuels differnt.....you must be losing a lot of that 'snap' that comes with 20% car race fuel.
CA
Please note my edited previous post.
Also, although I did lose some power from switching, but for me 1/2 price of the fuel justifies it. Stay tuned I will post some pictures and videos running on that fuel.
IL
ive always had all kinds of luck with the traxxas 20%, if the smoke gets thin, check the temp, it will usually be lean. truck runs bout 230 all the time and the 3.3 runs like a striped ape... ill stick with the high oil. if i run out of traxxas and i dont want to make the 40 mile one way trip to the lhs ill throw in some of my 10% plane fuel, tune for it, and run like always. the 2.5 i just pulled out had 6 gallons of top fuel through it and however much plane fuel through it and it still runs strong, i keep it for a backup for the 3.3
CA
I remember 3 years back when I first bought an rc. It was a Traxxas and I used traxxas fuel. I remember that it overheated even with smoke coming out. I was surprised to find out that Traxxas fuel is made by powermaster. It says on their website.
http://www.powermasterfuels.com/about.html
I've also had good luck with Wildcat fuels. Both Wildcat and Powermaster run at about 13-17$ depending on nitro content. So Traxxas is reselling for double the price and making $, who can blame them for that Powermaster and Wildcat both have 16-18% oil. And I've always had good luck with higher oil content fuels. Especially when it comes to keeping the temps down. The extra oil will provide the extra protection at high revs and for novice drivers who might tune on the lean side.
TX
yeah the old top fuel was made by power masters... but traxxas new powerplus if unknow...i belive it only has syn. oil now. so i guess they ditched the cator oil
not to jack anyone's thread but i was able to buy a brand new t-maxx 3.3 for $150 cause the guy was running traxxas top fuel and it wasn't staying tuned so he gave up on it.
NC
I run Traxxas Top fuel in my maxx, and it runs like a raped ape.
I run odonnells in the past and I dont see much difference, besides the smell.
