Revo 3.3 issues....
AB, CANADA
Revo 3.3 issues....
I am new to the RC world and recently purchased a Revo 3.3. I had it out the other day and was bashing with some friends, took a jump and fell from about 6 ft up onto dirt right on the engine. It stalled and when I started it, it revved out of control. I pulled the engine to discover a broken engine mount which Ireplaced. The over revving problem is still continuing. Anyone have any idea what this could be? Tranny issue?
AB, CANADA
RE: Revo 3.3 issues....
It is revving uncontrolled...and I did check the crank case and didn't see any cracks. Spur gear seems fine. I might yank it apart again and seal the carb.
AB, CANADA
Carb slide valve? I reset the factory settings. I assume the valve slide is what the idle screw ontrols. This is at the factory gap.
AB, CANADA
Pulled the engine out...definitely no cracks I could see. Linkages are fine....I'm guessin this must be a leak....only thing I can think of.......
