erevo is slow?
erevo is slow?
Hi guys, rc newbie and especially electric newbie.
I picked up a used e-revo that was born brushless, with a new evx-2 and new and broken in titan 775. it has centre diff, swaybars, buggy tires and other stuff.
from what i was told, it was stock gearing.
so today i finally got my 2s lipos running, i set the truck up, and its slow. good response but it doesnt take off like others i see on youtube etc. probably only does 20 or 30kmh. reverse kicks in faster than forward, it can kinda tilt the back up in grass going from stop to full reverse, but forward from stop no wheelie, not even close.
im wondering if maybe i need to set the esc? far as i know it should be set already. batteries were all charged to within .1 of 4.20
could it be the centre diff? i doubt it has the stock oil in it.
its got the right speed for a track, minus a straight, i dont understand. i thought it would be as fast or faster than my nitro buggy(vx .18), but the buggy with 1 gear and a broken 2nd gear is faster. i WILL go to the track, but it will be for bashing more so, and a slow vehicle is no good to bash!
it was rebuilt before i bought it by a guy that raced it for a year or so, so im left wondering whats going on. hoping i dont need to start disassembling it, since i dont know how the revo is built yet.
thanks
thanks
RE: erevo is slow?
it is a new titan 775, only broken in.
ofcourse this is going off what i was told, but i dont think the guy was dishonest.
edit: the guy i got it from has a long track record of sales, and from what i found nothing bad ever surfaced.
RE: erevo is slow?
thats kinda over my head at the moment, i should have everything to put it back brushless besides motor, but i rather not if there is a simpler, cheaper soultion.
i dont want 100mph, but at the moment i could probably run faster than it.
AB, CANADA
RE: erevo is slow?
Brushed E-Revos top out at around 30 to 35 mph. There really isn't much else you can do other than install a brushless sytem...then watch out! My E-Revo was super slow compared to my Revo 3.3...ended up selling the E because I couldn't, at the time, afford to go brushless.
RE: erevo is slow?
Maybe your Evx-2 is programmed on learner's mode or something...which is 50% forward and 50 reverse. Do you have a LVC for those lipo's because I know the Evx2 isn't compatible otherwise, the lipos would just blow it up!
RE: erevo is slow?
ive got 2 sensors, one on each.
i just ran for maybe 20 mins, i was still at stage 2 of 4 on the sensor.. blue, flashing blue, red, flashing red
ill see if i can program it..
as for it topping out at 30-35, i would estimate its going 20, i can outrun it and people can run like ~25mph/40kmh
NY
RE: erevo is slow?
no offense but the fastest human in the world can only run 23.35mph so im pretty sure a normal human cannot run 25mph. check for Binds anywhere. make sure everything is Free rolling
RE: erevo is slow?
according to google 25mph has been broken by a runner before.. give me a break, im canadian, i dont use mph..
so, i think stock tooth is 19? ill want to try 17? off to search
RE: erevo is slow?
try 21, at least that's what I and a lot of other people seem to running on our Emaxx's. That should give it plenty of top speed, but if you are running 19 right now, I would think it would have pretty good torque. But then again like FP said check for binds, see if it can roll when you just push it...
RE: erevo is slow?
it rolls fine.
how exactly would i figure out top speed on paper? i think stock gear is 19/69, 4s lipo(14.8v), and im pretty sure my crimefighters are the same size as stock tires.
this is whats on the truck:
EVX-2 and titan 775, 2x 2s 5000mah 20c
-Traxxas wheelie bar
-Traxxas center diff
-Traxxas HD servo saver spring
-Tekno sway bar kit
-HPI SF5 Metal gear high torque servo
-Aluminum servo arm
-Proline aluminum single servo arm
-Proline XTR truggy wheels and Proline Crimefighters
oh, and im wondering what you guys would pay for this. came with the stock (talon) tires used, esc and motor new, extra chassis. stock radio, all the brushless parts and suspension parts, shell has a little melt damage but close to none from when the guys brushless had a meltdown otherwise its good, and the servo works great besides the arm screw came out and i had to find a replacment from my buggy. oh, and the truggy tires are mint. and it WAS spotless....
im not sure if i got a good deal or not.
the EVX-2 puts the batteries into series internally, right? thats what the old owner said.
-Tekno sway bar kit
-Aluminum servo arm
RE: erevo is slow?
did i read that it "just had a titan 775 put in it"?
did i read that it goes faster in reverse than forward ?
if so , REPROGRAM your esc, if you dont lknow how to do it ,go to traxxas .com and dowload the manual, it's free.
RE: erevo is slow?
ORIGINAL: Ellis420
thanks
thanks
I hear ya man.... WHOWOULDWANTTHISROACH???????
http://www.youtube.com/watch?v=mqPt0KS2CtI
RE: erevo is slow?
ORIGINAL: rcslsafut
got ahold of the guy, he never ran it like it is now, so i just need a gearing change.
RE: erevo is slow?
SOOO...
i opened up the truck, there was a 12t pinion and 62t spur, and i picked up a 15t and 18t pinion.
the 15t is faster, probably perfect for a track. the 18t is a bit faster still, but its still not as fast as my buggy. i think it can outrun me now. motor is getting warm now.
now, my issue is my center diff.
when i go to full throttle, the front tires just spin like hell. the rear sit still. truck doesnt come out of turns at very good speed.
that means i need thicker CD oil, correct? the guy i got it from said he put 6k in, while i see most people put in 500k-900k.. is it possible he actually put in 6k? i want to be able to maybe pick the front up, not flip. i DO have a wheelie bar..
RE: erevo is slow?
ORIGINAL: Ellis420
SOOO...
SOOO...
