need some more help
need some more help
ik i ask for help alot, its only cause i barely know anything about nitro trucks and engines. can fliping a t-maxx into a brick wall cause the clutch to disintegrate, mess a spur gear up, and a piston to break but not the motor mount.
RE: need some more help
Truck hits wall, engine moves or chassis flexes, spur gear strips, engine rpm's go above the safe zone due to no load, piston skirt/clutch breaks. Happens all the time...
engines can take some serious G forces as well...it's more likely that it was overrevved like crazy and broke that way. under normal operating conditions i've crashed cars from 60 to a dead stop and the motor is fine everytime. of course, the car needs several hundred in repair at that point.
ORIGINAL: Snook Man
