S MAxx Runs Backwards?
Posting this for a friend (I'm a plane guy). He just did some work on his gas S Mazz (no reverse gear installed) and now it only goes backwards. Any thoughts?
RE: S MAxx Runs Backwards?
ORIGINAL: wannabflyboy Posting this for a friend (I'm a plane guy). He just did some work on his gas S Mazz (no reverse gear installed) and now it only goes backwards. Any thoughts? |
Where would these bearings/clutches be found?
Or the diffs are installed upside down. I did that on my Revo the first time I reassembled it.
SMaxx has only 1 diff (rear), it is installed upside down.
<u>If</u> the engine were running backwards the OWB in the transmission would not allow it to move at all. |
ORIGINAL: Snook Man SMaxx has only 1 diff (rear), it is installed upside down. <u>If</u> the engine were running backwards the OWB in the transmission would not allow it to move at all. |
<p class="MsoNormal" style="MARGIN: 0in 0in 0pt"><font face="Times New Roman" size="3">All Maxx trucks (T/E/S) have diffs that can be easily be installed upside down.</font></p><p class="MsoNormal" style="MARGIN: 0in 0in 0pt"><font face="Times New Roman" size="3">It is a very common mistake with those models.
Even the Revo models have diffs that can be istalled incorrectly, they have an UP stamped on the diff housing and it still happens:)</font></p> |
Yes it does! When I did it, I looked for the up markings, aligned it properly, then put it down for a second to grab another part. Inverted it without realizing it, and presto, reverse gearing!
does anyone know the part number for the parts needed to make the s maxx to run reverse and to make it 4x4
Here's the kit to make it 4X4 part#5191X.
http://buy.traxxas.com/product_info....oducts_id=7527 Also check diff installation of the front. The other common mistake is to flip it and the wheels spin in opposite directions. |
