Erevo Erbe bashing 6S 18/54
1 Attachment(s)
Just curious how many of you guys are bashing the ERBE with 18/54 gearing with 6S or 22.2 Volts? I only run the 6S and it is awesome offroad. Had the 65 spur and wanted a little more offroad speed. Put in the 54 spur and it gives me about another 10 mph. Traxxas Castle gearing chart doesn't recommend this gear ratio on 6S. Im not having any temp issues but just wanted to see if any of you guys are running this setup in your rig.
RE: Erevo Erbe bashing 6S 18/54
yeah it's gets you around 50-55 MPH with that gearing. and heat shouldn't be an issue
I wouldn't see an issue unless you are braking or doing some hard stopping all the time.
