RCU Forums
-   Traxxas Monster Truck forum (https://www.rcuniverse.com/forum/traxxas-monster-truck-forum-251/)
-   -   looking for some info TMAXX (https://www.rcuniverse.com/forum/traxxas-monster-truck-forum-251/11653323-looking-some-info-tmaxx.html)
redwolf850 08-25-2018 04:23 PM
If I was to buy a trx 2.5, would the rotary carb from a trx .15 fit?? Or how would I go about getting a rotary carb that would work, without using the converting kit
controlliner 08-30-2018 04:18 AM
No, the .15 side exhaust has a carb boss that is @10 MM. The 2.5cc (also a .15) has the carb boss at I believe is around 15MM. So the carb for the pro 15 will not fit the 2.5 rear exhaust.
Also, even if you could fit the smaller carb to the 2.5cc rear exhaust engine, the pro 15 carb bore is 5 mm (too small) and the engine although would get excellent fuel economy, it would perform like poo.
tcharger 09-01-2018 08:25 AM
A good quality rotary carb would cost you more than the conversion kit. That being said, if you still have your mind set on getting a rotary carb I can look and see which rotary carbs I have that would fit
