side exhaust on revo
Anyone have any info on a side exhaust on a revo.Thinking about it not sure if it is good or bad info please
RE: side exhaust on revo
side exhaust is bad. you get oil and crud all down the side of your truck. rear exhaust means cleaner truck. but then again i guess it is person preference.
from what i hear side pipes or good rear pipes are bad!!!
well i like the rear pipe... but the side pipe seems to be faster. you can run a larger pipe.. well for us big block guys thats good. if your running a 2.5 or 3.3 im not sure its worth it. maybe it is?
What bodies are you using when mounting a side pipe. I have a RB C5 in my revo and right now I have a Trinity high flow pipe, it works pretty good now but it would be nice to have a side pipe
The Slayer runs it. It says he uses a nitro rustler manifold, and then runs any pipe he wants.
There is some good info here from the Traxxas forums about running a side exhaust.....
http://monster.traxxas.com/showthread.php?t=335993 - bspate - |
Two reasons why i had mine on the side.
-if you got a revo, you'll encounter multiple times that the shock ends will pop out. Aluminum or plastic it will pop out due to the fact that the exhaust pipe transfertoo much heat and expand the end rod. -easier access to the rear end. -your revo will look like a truggy when you do this mod. |
thank for the help ill think about it
ORIGINAL: weez440 side exhaust is bad. you get oil and crud all down the side of your truck. rear exhaust means cleaner truck. but then again i guess it is person preference. |
Do yo have any troubles with damage to the pipe, doesn't look to protected like an 1/8 scale
It may not be protected as much, but just try killing a 1/8 buggy pipe. It is not easy. Since it is high up, and if you can get it under the body, it will be covered by the body, giving it a bit more protection. But it shouldn't be bad unless you land on the side with the pipe, from a 10 foot drop.
Every one says its not a good idea untill they get a mid block or big block engine and then all of a sudden they can't keep they'r engine tuned, they then realize that there are no big block pipes t ocome out of hte rear of the revo. So what do you do? You do the following.
If you want higher rpms/ higher hp go Ofna JP-2 pipe If you wnat more torqu and low end power go Ofna JP-1 If you want the best over all get the Ofna JP-3 Hears what i did for my sirio 23, wich was also bought for my next engine wich will be the Novarossie 528 or the Ninja 28 if its out by then. http://scrcracing.zoomshare.com/albu...at/webchat.css http://scrcracing.zoomshare.com/albu...at/webchat.css http://scrcracing.zoomshare.com/albu...at/webchat.css http://scrcracing.zoomshare.com/albu...at/webchat.css http://scrcracing.zoomshare.com/albu...at/webchat.css http://scrcracing.zoomshare.com/albu...at/webchat.css |
For those who want a side mounted Pipe, and still have a small block, here is the solution:
First buy the O.S. .21 RG header. http://www2.towerhobbies.com/cgi-bin...?&I=LXNW29&P=7 Then buy pipe of choice if you don't already have one. Screw the O.S. header on. It should fit. Next put the pipe on, and secure it with the manifold coupling. Done. Find some way to secure the end of the pipe to the chassis, and you are done. It will fit if you are using a pull start, and any 1/8 buggy screw on manifold should work with a pipe if you are using a bump box, and sealed back. Note, this is for TRX 2.5 and 3.3 owners only. For BB's, a normal 1/8 buggy pipe and header will work fine, and should make it easier on you. So go buy a BB!! :D |
There really is a large difference in pipes also...I use an SH max speed pipe with an ultra torque header with the mach 28 in the revo..it is a perfect match for the engine....I have used jp-2, os t2050, and losi ht pipes with an axial 32, os30, and sh 28 p6 (lst2)...each of the engines ran different with the various pipes! The jps-2 is a good all around pipe, but does not have as much top end as the os pipe (with the os30 and sh 28)...what I am trying to say is pipes can make a large difference in how the engines run and perform....and yes, a side pipe is sturdy on a revo...
