RPM axle Carriers PROBLEM
Ok so i had to swap out my axle carriers on my revo. I only switched the front and it seems the driveshaft has some wiggle room. When i got the tires on it seems like there is too much play due to the driveshaft not being fully snug. Have i mounted these wrong or is that just the way they are?
RE: RPM axle Carriers PROBLEM
did u try and snug the ball screws down a little bit?
whats a ball screw...?
anyone else on this?
the ball screw is the screw on the end of it that faces the wheel tighten them down and it won't wiggle as much
i guess another term for it is pivot ball. its what connects the axle carriers to the A arms. when u thread them in u should watch the threads and as soon as the threds disapear into the end of the a arm u stop. check it out. it could be ur problem.
